Driving a DC Motor with variable speed using PIC 16F877 (C language used)
Discussion in 'Embedded Systems and Microcontrollers' started by Gtofig, Feb 6, 2008.
  1. Gtofig
    Jan 4, 2008
    14
    Hello.
    I need to programm a PIC to drive a DC Motor, using a C language (I use mikroC progamming environment). The speed will be constantly changing during the operation. Say I have a float variable X, which represents desired speed in cm/sec. I am using 2 PORTB pins as motor inputs (forward and backward motion inputs of DC motor).
    I know that this kind of things are done using Pulse Width Modulation Method (PWM), but I couldn't find any example in C language (I don't understand Basic well). Any suggestions will be appreciated.
    Thank you,
    Gtofig
  2. Gtofig
    Jan 4, 2008
    14
    Note: Is it necessary to add some additional analog circuits between the PIC and the motor?
  3. h.d
    Oct 22, 2007
    150
    whats your motor parameters(voltage,current,power)?
    if you work in power you need MOSFET or IGBT and trigger it by the PWM signal
    which come from thee PIC
  4. Gtofig
    Jan 4, 2008
    14
    motor is weak,but exact specification are not known yet. does anyone has any examples of C code for this? Probably just writing PORTB.0 = X will not work,because X is real value, while output is just a bit. How do I do the pulse width modulation, and adjust duty cycle in the program? I know that motor speed is related to frequency of High signal of the output bit.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
