Driving a 48V 400W DC motor from a single phase 220V 50Hz AC: Comparison between two topologies.
Discussion in 'The Projects Forum' started by BlackMelon, Apr 12, 2016.
  1. BlackMelon
    Mar 19, 2015
    33
    In my mind, there are two ways to do this. However, I don't know pros, cons, and cost-effectiveness of each.
    http://lh6.ggpht.com/_X6JnoL0U4BY/S26tzJ3HCtI/AAAAAAAASCI/p_k2WzgjVb4/tmp166_thumb.jpg?imgmax=800
    The link above presents driving one from SCRs. The 4 SCRs can't reverse the motor's direction, thereby requiring another four to do so. However, as shown, the topology is work best with 3 phase.
    The other way is using a bridge rectifier and a dc-dc converter to convert 220V to 48Vdc. Subsequently, a h-bridge mosfet driver is conneted to 48Vdc to drive my motor. This allow me to control both speed and direction. However, the converter requires a transformer for safety. I'm afraid that the transformer will dump the overall efficiency down.
    Which way should I take? Is this a trading off between smoothness of dc voltage across the motor and the overall efficiency?
    BlackMelon
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,523
