I have an Instrumentation amplifier feeding into a 1 op amp 60Hz notch filter. The output of notch filter is feeding 3 bandpass multi feedback filters ( 4th order, 2 opamp each). Do i need to put any thing between the output of the notch filter and the 3 filters or can i connect all 3 to the output of the notch filter?
For another circuit i have a instrumentation amplifier that needs to feed a comparator,ADCand 50 Ohm line driver, what should be between the output of the IA and the 3 devices?
any help would be great.
