Driver_using Transistors
viswaimpulse
Joined Nov 26, 2010
I need to make one driver using transistor which carries 60mA current .
Based on the TTL input to the base the driver should give 2V ,60mA.
Note :D.C-D.C convertor gives 5V ,so i need to step down the 5V to 2V and load the current od 65 mA .
Pls hepl me on this .If you send the circuit it will be usefull for my project
waiting for your reply .
Thanks & Regards
Visu.
