driver or resistor for this high powered LED???
Discussion in 'The Projects Forum' started by riley78, Nov 7, 2012.
  1. riley78
    Nov 7, 2012
    Hi all. Hi all ...
    I need help with this high powered LED im buying, the data sheet is on this site aswel.
    http://uk.farnell.com/ledengin/lz1-0...lue/dp/1678946
    Basicaly could some one please recommend a driver or resistor I need to run this LED, i was going to power it by just using a 12v adaptor.
    I did speak in online chat to a guy from the site he recommended this driver.
    http://uk.farnell.com/xp-power/ldu24...0ma/dp/1738296
    But as you can see the LED is £15 to buy so i want to make sure I get it all right.
    any help would be great guys.
    can someone help me with this high powered LED as shown here with data sheet.
    http://uk.farnell.com/ledengin/lz1-00db00/led-5w-dental-blue/dp/1678946
    could someone pls recomend a driver i could purchase to run it of a 12v power supply.
    as you can see the LED is expensive so i dont wish to get this wrong
    thnks for your help
    Pete.
  2. John P
    Oct 14, 2008
    1,638
    225
  3. mcgyvr
    Oct 15, 2009
    4,787
    973
    What do you intend to mount/solder this LED to?
    Also what do you intend to do for heat sinking?
