Driver motor DC speed control
Discussion in 'The Projects Forum' started by risky fajar, Oct 9, 2014.
  1. risky fajar
    Oct 8, 2014
    41
    how to control the speed dc motor... ??? whather it can be controlled used microcontroller?
  2. ISB123
    May 21, 2014
    1,240
    531
  3. mcgyvr
    Oct 15, 2009
    4,793
    976
    or a microcontroller/transistor/mosfet (pwm)..
    or an off the shelf DC SCR/PWM motor controller..
    obviously all DC motors are not the same..
    A proper/detailed question would include specifications on this DC motor.
  4. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    Off the shelf there are KB/Baldor SCR or PWM controllers, for the very simple solution, there are numerous simple PWM on ebay for ~$15.00.
    Max.
  5. risky fajar
    Oct 8, 2014
    41
    thank to you answer..i will question any more..
    used motor DC series....when speed motor dc low, whather torque of motor dc be decrease?? how mien speed is low we obtained torque advance ?
  6. risky fajar
    Oct 8, 2014
    41
    how mien controlled SCR..??? whather using PWM???
  7. risky fajar
    Oct 8, 2014
    41
  8. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    DC motor Torque curve is generally fairly flat, starting at maximum at zero rpm dropping when maximum rpm limit is reached.
    SCR bridge is usually the cheapest method, followed by the more favorable PWM.
    More is needed on your application.
    Max.
  9. risky fajar
    Oct 8, 2014
    41
    if i want control speed motor dc constant..what method which most efficient?? i still general with speed control motor dc series...
    risky
  10. Bernard
    Aug 7, 2008
    4,246
    423
    Go back a read post # 3, & supply an answer. You may need to attach a tachometer to adjust to a given speed.
  11. risky fajar
    Oct 8, 2014
    41
    ok thanks for your answer... what is sensor can be used mearsured speed?? whather directly connect to tachometer??
  12. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    If just velocity a DC or digital AC tach can be used, if position, then an encoder is needed.
    Max.
  13. risky fajar
    Oct 8, 2014
    41
    ok max.. whather method can be used?for speed constant..whather control pulse PWM for controlled speed of motor dc..
  14. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    Your IMG shows a PID loop via encoder, as already mentioned this is suitable for precise positioning, if you just want constant velocity, the tach method can be used, usually tach/velocity loops can control to within 1%.
    Either methods can be from self programmed Picmicro or other µp methods etc to off the shelf industrial controllers.
    You need to specify your exact intentions, and any preferred or capable methods.
    Max.
  15. risky fajar
    Oct 8, 2014
    41
    to obtain a high torque gear box whether to use????
  16. Alec_t
    Sep 17, 2013
    5,980
    1,138
    If you want to.
  17. risky fajar
    Oct 8, 2014
    41
    ok thanks
