Driver ic
Discussion in 'General Electronics Chat' started by onceinalifetim, Oct 10, 2014.
  1. onceinalifetim
    Feb 9, 2014
    27
    I'm suppose to choose a driver ic for my IGBT.
    i would like to know what is the different between high side vs low side?? i need high voltage to power up my IGBT...
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    A low-side device connects one side of the load to ground (GND)
    a high-side device connects one side of the load to a positive supply voltage.
    Notice that in the case of a negative supply these definitions would be reversed
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    I think you have that reversed, if by "device" you mean the switch (e.g., a mosfet or IGBT).
    Edit: Papabravo's description is correct. I mis-read it.
    This is a high- side switch. The load connects to ground. Source: International Rectifier, AN-978
    A low-side switch has the load connected to the high-voltage rail. The switch is between the load and ground.
    John
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Reread what I said carefully. I agree that the MOSFET in the picture is a high-side switch. It connects one side of the load to the positive rail when it is turned on. The other side of the load is connected to ground (GND)
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    Thank you. I absolutely mis-read it. My original reading was something to the effect of "one side of the load is connected..." not the device connects... Sorry.
    John
