Driver for mosfet
Discussion in 'The Projects Forum' started by renatomassa88, Jul 13, 2011.
  1. renatomassa88
    Jun 12, 2011
    8
    Does anyone know a good driver for the IRFPE50 mosfet?
    f=50kHz, duty cicle=0,2->0,45
  2. R!f@@
    Apr 2, 2009
    8,791
    771
    the driver depends on the type of signal used to drive the FET for a typical level.
    Give the drive signal specs
    But a short answer is that a low value R in the range from 10 to 47 ohm at the gate is sufficient for any drive requirements
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You really need to describe your application better.
    Is this going to be used as a low-side switch? Or are you going to build an H-bridge? Something completely different?
    What will be the source voltage and current that you will be switching?
  4. #12
    Nov 30, 2010
    16,704
    7,354
    I ran across this a couple of years ago. No idea if it will work for you.
  5. renatomassa88
    Jun 12, 2011
    8
    Does anyone know how can
    I can calculate a proper
    mosfet driver?
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
