hi
i've been trying to use a ac motor with power ratings of 5 amps 235 v and 350w and i have connected a fan to it.i also have a heater with range 0-1000'C with ratings of 220v and 5 amps. am using a spilit range controller to control temperature inside a furnace using the above devices. the output i get is 4-20 ma from the controller. this i've converted to 1-5v.am using 2 clippers to divide the output voltage into 1-3v and 3 to 5v.i am not sure bout using IC741 to split the voltage cos it saturates and does not give me proper output....
now i have been searchin the net for a proper drive circuit for driving the motor and the heater.. i thought of using a triac and do phase control to control voltage for the motor. i don no how to control the temperature but i guess an scr driver can be of some use.
i am from india so getting 220v is not a difficulty.....previosly i had a dc motor to do the same for some reason my professor here asked me to drop the idea of using dc motor.
i am basically an instrumentation student and am little weak in electrical.pls help me with the following questions:
1) is using a clipper wise to divide the controller output voltage into 1-3v and 3-5v?
2) somebody pls help me with the drive circuit for the heater and the blower.
3) is using a driver to control the voltage the best method or using an amplifier the best method???
thanks in advance
thanks in advance
