driver circuit for ultrasonic sensor
Discussion in 'The Projects Forum' started by tyc8159, Jan 14, 2007.
  1. tyc8159
    Dec 6, 2006
    6
    We currently doing a circuit to drive a 2MHz ultrasonic sensor. The results we got is inconsistent echo signals, even we put a aluminium plate 50cm in front of it. Is anyone have this exprience before? I also looking for some useful resources in designing the circuit. Please leave your opinions here. Thanks
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    2 MHz is quite high for an ultrasonic sensor. Can you post a schematic to give us a better feel for the circuit you are using?
    hgmjr
  3. ropotic
    Jan 15, 2007
    2 MHz may be good for an ultrasonic sensor. Can you post a schematic to give us a better feel for the circuit you are using?
    ropotic
    mostafa_sh500@yahoo.com
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    2 MHz is way too high for ultrasound. The mechanical element would have to be moving above the speed of sound.
  5. Ganapati
    Aug 2, 2006
    Which type of transducer you are using ?
    I am using electrostatic transducer & I am getting good results.
    If possible let me have look at the circuit you are using.
    If you are using electrostatic transducer, I will send you my circuit.
    suhas_avg@yahoo.co.in
    - Suhas
