Driver circuit for 8 LED in series
Discussion in 'The Projects Forum' started by medic mad, Nov 26, 2015.
  1. medic mad
    Oct 10, 2015
    15
    I am looking for a driver circuit or any simple circuit to glow 8 green LED in series/parallel using 9 Volt battery ..
    i have attached the LED datasheet
    its forward Current 20 mA.
    forward Voltage 3.1V
  2. Alec_t
    Sep 17, 2013
    5,968
    1,135
    The simplest circuit would be 4 parallel strings, each string comprising 2 LEDs in series with a 150 Ohm 1/4 W resistor.
    LED current would reduce as the battery voltage dropped. A more complex circuit would use a respective constant-current 20mA source for each string.
    Either way, the total current would be ~80mA, so a little 9V battery wouldn't last long.
    medic mad likes this.
  3. medic mad
    Oct 10, 2015
    15
    thanks for the prompt reply is there any circuit to improve battery life for the above mention design 4 parallell strings and 2 LED in series
  4. mcgyvr
    Oct 15, 2009
    4,787
    973
    No unless you are willing to sacrifice brightness..
    If so just change the resistor value to change the string current.
    Drive them at 5mA instead of 20
  5. spinnaker
    Oct 29, 2009
    5,065
    1,176
    Take a look at a buckpuck. I use one from this company but with a larger array than you have,. They work very well. You might be able to find a smaller device. It would be the easiest way to go.
  6. medic mad
    Oct 10, 2015
    15
    thanks to every one.
    kindly find the attachment and tell me if i need to improve the circuit.
  7. Dodgydave
    Jun 22, 2012
    5,143
    768
    Looks good. 7.5 V with approx 19mA led current, but the Lm317 needs 3V minimum drop input to output.
    I would have made the 240R resistor 120R, and used 610R instead of 1K2, but it still gives same result.
  8. Alec_t
    Sep 17, 2013
    5,968
    1,135
    To get maximum efficiency a DC-DC boost converter could be used to raise the 9V to > 25V, so that the 8 LEDs could be connected in series and draw about 20mA total.
  9. medic mad
    Oct 10, 2015
    15
    thank a million sir,one more help how to include 8 photo darlington in same circuit op560a.pdf
    is it possible to use all 8 PD in same circuit or if using 9v battery is not suitable i will go for 12v adapter
  10. Dodgydave
    Jun 22, 2012
    5,143
    768
    Your lm317 needs a minimum of 3V drop to make it work, if you want to input 9V, your maximum output is 6V for it to keep up.
  11. Alec_t
    Sep 17, 2013
    5,968
    1,135
    The circuit would depend on what you want to do with them.
  12. medic mad
    Oct 10, 2015
    15
    is it possible to make this circuit? by merging 9v to 7805 and adding 8 photodarlington in parallel with 10k resistor
  13. spinnaker
    Oct 29, 2009
    5,065
    1,176
    You do not want to use a 7805 if you want efficiency. You want a buck regulator. The 7805 is a linear regulator. And you really want to regulate current and not voltage.
  14. Colin55
    Member
    Aug 27, 2015
    204
    21
    absf likes this.
  15. spinnaker
    Oct 29, 2009
    5,065
    1,176
    Nice. Do you have that in a traditional schematic? Might be easier to follow. How many wraps on the bolt? Or what value coil can be used in it's place?
  16. Alec_t
    Sep 17, 2013
    5,968
    1,135
    No, because that circuit doesn't show any photodarlingtons ;). Where did you want to connect them and what would they be driving?
  17. Dodgydave
    Jun 22, 2012
    5,143
    768
    that circuit is better with the 7805, are you trying to make a torch?
  18. medic mad
    Oct 10, 2015
    15
    sorry forget to add schematics
    please consider the npn darlington as photo darlington op560a
    is it possible to to add both circuit? and can it be driven by 9volt battery? View attachment 92802
  19. medic mad
    Oct 10, 2015
    15
    [that circuit is better with the 7805, are you trying to make a torch?]
    no this have to connect with opticfiber oneside led and the other side photodarlington
  20. Dodgydave
    Jun 22, 2012
    5,143
    768
    I wouldn't use a Lm317, better to use the 7805, it will power all the circuit both leds and receivers,
