Driver/Buffer datasheet voltages
SPQR
Joined Nov 4, 2011
379
Hello again,
I'm going through a "driver/buffer" stage, and have purchased some representative samples of about 20 different types.
Before I start building circuits, I'd like to learn a bit more about each one.
I'm building a spreadsheet with a series of variables regarding each buffer, and I'm stumped on some voltages:
SN74HC125 -
Introduction - "Wide operating voltage range of 2-6V"
Page 2 - "supply voltage range - -0.5-7V"
Page 3- "VCC supply voltage - 2-6V"
Why the difference?
SN7417 -
"open collector" - I understand the implications of this
"sinking 40mA" - this I understand
Page 2&3 - "supply voltage Vcc = 7V"
__________"output voltage = 15V"
Don't think that this is a voltage amplifier, so does the output voltage mean that you can attach up to 15V to the open collector? Like a 15V motor?
Thanks again.
On the sn74hc125: the -0.5 v to 7 v number is the absolute maximum supply range that would probably not damage the chip. The 2 v to 6 v range is the recommended operation range over which many of the other parameters are measured. So, although you could put 1 v on the supply, since it will not damage the part, you are not supplied with any guaranteed characteristics for the chip outputs...
On the sn7417: the open collector output means there is a BJT transistor with no connection to its collector inside the chip. The output load can be connected between the collector and a voltage as high as 15 v, so a 15 v motor would be one option. When there is no current flowing through the load, the voltage at the collector would be 15 v, the maximum allowed by this part before the transistor collector can be damaged.
SPQR
Joined Nov 4, 2011
379
Very, very nice - Thank you!
I've read many datasheets over the last few months and I marvel at such a fantastic, organized, engineering profession,
that can have such variation in nomenclature.
So for the 125
Two different concepts with three different names.
So I'm going to label the columns with MY names::)
Supply Voltage = Sup V
Tolerable Supply Voltage Range = Tol Vcc
In terms of the 7417, it's what I figured - that would make sense.
So my new name:
Maximum Applied Voltage to Collector Output - Max Coll Volt
Thanks again! Very helpful!
w2aew
Joined Jan 3, 2012
219
The key is to look at the headings above each of the tables. On page 2, it says "absolute maximum ratings". This are the ratings, which if exceeded, will damage the part. On page 3, these are the "recommended operating conditions". Self explanatory.
SPQR
Joined Nov 4, 2011
379
Yep, just noted those!
I'll have to be REALLY carefull in future.
Thanks!
I think the motor example was just to try to understand the concept of a 15 volt output on the part. The OP stated he knew the part on could sink 40 mA. So, motor specifications were not questioned.
ScottWang
Joined Aug 23, 2012
7,398
The motor specifications maybe not the question, but when a load needed 40mA connecting to the 40mA sink could be caused a problem.
SPQR
Joined Nov 4, 2011
379
Exactly!
In terms of the open collector output, I usually think of motors/LEDs/solenoids being connected and "doing something".
It was a random example that I understand, at my level.
