drive relay coil directly from reversed polarity motor
Discussion in 'General Electronics Chat' started by Jan Rune, Mar 8, 2014.
Thread Status:
Not open for further replies.
  1. Jan Rune
    Apr 22, 2008
    17
    Hi(again),
    I need to trigger the coil on a relay every time a motor is turning in either direction. Is it ok to just connect the relay directly as showed in schematic? My guess is that the motor driver allready are taking care of protecting the rest of circuit and i dont need a suppresion diode. But are there anything else that can go wrong? Any pitfalls?
    Thank you
    Jan Rune
  2. #12
    Nov 30, 2010
    16,663
    7,307
    Looks good to me. I do this all the time with relay driven motors. That doesn't account for protecting your driver, but I think the relay coil is insignificant compared to the motor.
  3. Jan Rune
    Apr 22, 2008
    17
    Cheers nr.12. that was what i was thinking/hoping.
  4. inwo
    Nov 7, 2013
    2,435
    315
    Will the motor ever run too slow for coil pull-in voltage?
  5. Jan Rune
    Apr 22, 2008
    17
    I wish i had the answer to that, but its all greek to me. The motor is in a lock that open closes a door lock. Its rated to 2 amps and just reverse the polarity to lock/unlock.
  6. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    You can't use a suppression diode anyway, because you change polarity.
    What are you using to drive the motor?
    For a door lock, have you considered a magnetic latch solenoid?
    Max.
  7. Jan Rune
    Apr 22, 2008
    17
    I know, i was thinking about using two relays. Sorry i didnt make it clear in this post as my other one was closed. I am tapping into a system that is taking care of the motor drive. I just want one option that is not there as standard.
  8. #12
    Nov 30, 2010
    16,663
    7,307
    Oh crap. We just got tricked into an automotive topic. Bad poster!
  9. Georacer
    Nov 25, 2009
    5,151
    1,266
Thread Status:
