Drive Full-Bridge with LM555-clock
Discussion in 'General Electronics Chat' started by DedeHai, Mar 22, 2009.
  1. DedeHai
    Thread Starter Active Member
    Jan 22, 2009
    39
    Once again I need your opinion:
    I have two H Bridges, double N-FET hanging on a 3V bus in a full-bridge configuration. The goal is to be able to supply the resistive load that is connected to the bridge with current in both directions, depending on whether the output of a LM555 is high or low.
    Having also a 15V supply line available, what would be a simple way of driving the bridge?
    If I just used two complementary (N and P) FETs as gate drivers for the bridge, switching two of the bridge-FETs each, in a complementary manner (meaning the P-FET switches A1 and B2 and the N-FET switches A2 and B1, A and B being the branches of the bridge), i have the problem of a possible shoot-through in the bridge because of lacking dead time control.
    I then came up with the following solution:
    Charge the gates of the "driver FETs" through a resistor (lets assume it to be 1kΩ) to delay the "on" signal but discharge the gate through a schottky-diode, giving minimal delay for the switch-off voltage.
    Could this work? Do I need a pull-up (P-FET) and pull-down (N-FET) resistor on the gates to properly reference the gate voltage?
  2. mik3
    Feb 4, 2008
    4,846
    63
    The purpose of an H-bridge driver is to supply current in both directions for the load. If you use PWM and the duty cycle is 50% then no net current flows. However, if the duty cycle is not 50% a net current will flow in either direction (depending on the circuit).
    Post your circuit to check it and give suggestions.
