Hi all!!!
I'm currently drawing a PCB for high voltage application which consists of some IGBT, capacitors, transformer using EAGLE software.
I will solder the components manually onto the board after the board is fabricated.
The voltage and current rating of IGBT is 300V and 15A.
I tried to draw the trace on board file using EAGLE as shown in file attached.
When I tried on larger trace width which is up to 6.4516mm (as the current rating is so high), the width of trace seems to be so much larger than the diode hole.
Will this bring any problem when fabricating the PCB?
Thanks for advice from you all.
