Draw the Moore graph. I need help.
Discussion in 'Homework Help' started by Ems1s7, Nov 21, 2014.
  1. Ems1s7
    Nov 21, 2014
    11
    Hi everyone,
    I need help with this problem:
    Draw the Moore graph of states of a sequential circuit, with one input (E) - 1 bit and one output (S) - 2 bits.
    The circuit have to detect the sequences 1 0 1, 0 1 1 and 1 0 0, and detection should be performed with overlap.
    The output should be 1 0 if the first sequence is detected (1 0 1), or 1 1 if the second sequence
    is detected (0 1 1), or 0 1 if the third sequence is detected (1 0 0).
    In all other cases the output should be 0 0.
    Thanks advance! Waiting for your answers.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Show us what you have done so far to solve the problem. Start with how many states you think you will need.
  3. Ems1s7
    Nov 21, 2014
    11
    For the first 2 sequences I'll need from 5 states, because we have 1 0 1 and 0 1 1, but with overlap we'll have 1 0 1 1,
    i.e. the machine start to search the second sequence, before to finish the first.
    I'm not sure how to integrate the third sequence... may be 1 0 1 1 0 0? But in this case the machine start to search the third sequence
    when the second finish.
  4. Ems1s7
    Nov 21, 2014
    11
    I have finally solved a problem.
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    How about a simple three-stage shift register? (Theoretically, that is eight states).
    Three 3-input NAND gates to decode the states you are looking for, followed by a couple of NOR gates to create the S outputs...
  6. WBahn
    Mar 31, 2012
    18,085
    4,917
    I agree that the 3-bit shift register is the most straightforward solution (at least in general) as I see it with a quick glance, but if the problem is to draw a Moore Diagram (which I'm assuming means to draw the state diagram for a Moore machine that implements this system), then you need no more than three bits of state, though the number of states may be lower and it is possible that you might not need all three bits of state.
    Start with you initial state (probably an assumption that you have seen nothing but zeros, but that that's a guess) and then walk through the possibilities. At each stage, ask what information you know about which sequence fragments you have seen and what each possible next input tells you. Just keep in mind that, as a Moore machine, ALL of the information that is retained in what the current state is and NOT on what the current input is, too.
  7. Ems1s7
    Nov 21, 2014
    11
    I agree with both of you. Thanks for your answers!
    Now I know what I have to do.
