drain-to-Source Breakdown Voltage
Discussion in 'General Electronics Chat' started by 1:1, Jan 30, 2007.
  1. 1:1
    Jan 25, 2007
    27
    Hai forum member,
    Refer to power MOSFET, what does drain-to-Source Breakdown Voltage mean, and how it effect on selection?
    Tokeda
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That is the maximum voltage the device is designed to withstand. Exceed it, and the FET will break down electrically. So, if you have a circuit that need 80 volts to be switched, don't try it with a 60 volt rated FET.
  3. 1:1
    Jan 25, 2007
    27
    Thank beenthere,
    It seem sensible enough for me. I have another question need help on it.
    My original project are using a single irf7389 HEXFET Power MOSFET (provide by IR), but due to some reason, i change it by using one SUP75P03-07 & SUP45N03-13L (both provide by Vishay). Could anyone help me look thru is that any problem with my changing?
    http://www.irf.com/product-info/datasheets/data/irf7389.pdf (Link for irf7389)
    http://www.vishay.com/docs/70804/70804.pdf (Link for SUP45N03-13L)
    http://www.vishay.com/docs/71109/71109.pdf (Link for SUP75P03-07)
    I was struggling on it, really need some one to help.
    Thank you,
    Tokeda
  4. dragan733
    Dec 12, 2004
    152
    1:1,
    What is the load current and load voltage at your project?
  5. 1:1
    Jan 25, 2007
    27
    Thank dragan733,
    The load voltage will be 15 volt.
    Tokeda,
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    You may find this tutorial of use to help you understand drain-source breakdown voltage and its effect on high-voltage Power MOSFETs.
    Dave
  7. 1:1
    Jan 25, 2007
    27
    Thank Dave, it is an excellent resources.
    Tokeda
  8. 1:1
    Jan 25, 2007
    27
    I was wonder is there any H-bridge chip are available in the market that able to drive by PWM (microcontroller) instead of using 4 Power MOSFET (2 N-channel & 2- P-channel)to fulfill the same task.
    Tokeda
  9. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
  10. 1:1
    Jan 25, 2007
    27
    Thanks mrmeval,
    But problem is, the motor is drive by microcontroller ECCP module, imply that have four logic input, so may be the H- bridge show at link above is not particular suitable and the selective motor is drive by 15volt.
    Tokeda
  11. dragan733
    Dec 12, 2004
    152
    Therefore, the control signal is with same voltage as the load voltage, and the control signal has same ground as the load voltage. And what is the problem?
