First post here.
I've got a small linear actuator that is controlled by a servo. The actuator's displacement is monitored through wipers connected to an Arduino. I want to have the actuator extend for x distance then retract to its original position.
The circuit shown is basically how I wanted to do it at first, just to keep it simple. Through a NPN transistor the Arduino activates the coil. While in normally closed position the actuator moves forward, but when the coil activates it stops moving until it returns to normally closed position and after a few cycles the contacts on the relay go kaput. Any ideas or advice on what I can do to get this setup working, or a similar setup to replace it.
Thanks!
Ignore the values in the schem. it's only a visual representation
Thanks!
