DPDT relay alternative
Discussion in 'The Projects Forum' started by RodneyB, Jun 10, 2014.
  1. RodneyB
    Thread Starter Active Member
    Apr 28, 2012
    654
    14
    I am making a pool ioniser. It is powered from a Polycrystalline silicon solar panel.
    Optimum operating voltage is 6 Volts and the optimum operating current is 0.05 amps.
    The circuit supplies 2 copper electrodes. I want to make them alternate every hour and was using a double pole double toggle relay wired as per attached drawing.
    I have a PIC10F200 which I can get it to toggle the output. I just don't know how or what I could uses in place of the relay.
    Any assistance will be greatly appreciated
  2. prairietech
    Mar 12, 2013
    5
    The relay you attached should work fine. Why are you trying to find a substitute?
    If you do use a relay, be sure the include a subbing diode across the relay coil to prevent damage to the output of your PIC.
  3. inwo
    Nov 7, 2013
    2,435
    315
    An h bridge should work as a substitute.
    The relay however will not work as shown, as when NO. contacts close, it connects + to -.
  4. #12
    Nov 30, 2010
    16,705
    7,358
    You got your criss-cross in the wrong place.
