down counter using 74193 ic
Discussion in 'Digital Circuit Design' started by Judy Ann, Oct 1, 2016.
  1. Judy Ann
    Oct 1, 2016
    10
    guys i need help! please give me an idea or schematic diagram of circ, about down counter using 74193 ic ..
  2. djsfantasi
    Apr 11, 2010
    2,905
    878
    • Down from what?
    • To what?
    • Do you know how it starts?
    • Will it run once or how will it reset?
    • When will it stop?
    Judy Ann likes this.
  3. Judy Ann
    Oct 1, 2016
    10
    DOWN FROM 0 TO 9 .. IT WILL RESET AT 0 THEN BACK TO 9...
  4. MrChips
    Oct 2, 2009
    12,636
    3,454
    Can you count from 9 to 0 backwards?
  5. Judy Ann
    Oct 1, 2016
    10
  6. djsfantasi
    Apr 11, 2010
    2,905
    878
    Is this homework? And there were a couple of my questions you did not answer.
    Have you read the datasheet?
  7. Judy Ann
    Oct 1, 2016
    10
    this is an activity, yes i have read the data sheet.. i have tried my idea but the count is 9-7-5-3-1, then back to 9..
    circuit must have a continuity sir, it will not run once...
  8. Alec_t
    Sep 17, 2013
    5,976
    1,136
    Post the circuit of your idea.
    Is the 'activity' a school/college project?
  9. djsfantasi
    Apr 11, 2010
    2,905
    878
    And how does it start? Just by powering on?
    Is the count from 9 to 0 or is it 9-7-5-3-1? Details are important?
    Assuming it's the latter sequence, is there something unique about it? Can you describe it to us? How would you represent it in binary?
  10. Judy Ann
    Oct 1, 2016
    10
    this is the schematic.. i need it for college project
  11. Judy Ann
    Oct 1, 2016
    10
    by putting the source on.. the count is from 9-7-5-3-1.. there is nothing unique .. when i turn on the source the clock pulse start then the 7segment just display 9-7-5-3-1 number again and again... 1001 - 0111 - 0101 - 0011 - 0001..
  12. Alec_t
    Sep 17, 2013
    5,976
    1,136
    Using the A,B,C,D inputs, what value do you need to load in to reset the counter?
  13. Judy Ann
    Oct 1, 2016
    10
    need the 1 NAND 1 value to reset the counter. 0101,0111,1101,1111???
  14. djsfantasi
    Apr 11, 2010
    2,905
    878
    Alec_T asked a good question!
    And may I add, there IS something unique about that sequence. Look at it again, either in decimal or binary...
  15. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    Have a good look at the binairy values of the A,B,C and D outputs.
    How do they relate to the wanted sequence?
    Also what values do you need at the input of the counter to start at 9?
    Bertus
    djsfantasi likes this.
  16. Judy Ann
    Oct 1, 2016
    10
    need 1001 value to start at 9.
  17. Judy Ann
    Oct 1, 2016
    10
    there is nothing unique , the circuit just display 9-7-5-3-1 values
  18. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I'm going to be a spoil sport and let you off the hook. In the given sequence the least significant digit is always a 1. So tie that input to the display high. What do the remaining digits do? That's right they go {100, 011, 010, 001, 000}. Those values concatenated with a constant, always 1, least significant digit, make up the desired sequence. Preset the counter to 4, aka 100, let it count down to 0, and reset the counter to 4 on the next clock after the counter reaches 0. Recognizing patterns is half the secret to clever logic and state machine design. It has always worked for me.
  19. Alec_t
    Sep 17, 2013
    5,976
    1,136
    I'm still puzzled. Do you want to count 9-8-7-6-5-4-3-2-1-0-9-8-7-6-........; or should it be 9-7-5-3-1-0-9-7-5-....... ?
  20. MrChips
    Oct 2, 2009
    12,636
    3,454
    Seems like the LSB is stuck high.
