doubt
Discussion in 'Physics' started by whale, Jan 14, 2009.
  1. whale
    Thread Starter Active Member
    Dec 21, 2008
    111
    in common emitter configuration,the collector current is product of gain(β) and base current,
    from whare the factor β comes?
  2. mik3
    Feb 4, 2008
    4,846
    63
    β is the current gain of the transistor which equals Ic/Ib
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    It is a function of the physical attributes of the transistor; namely doping concentrations in the n- and p-type semiconductor parts, physical dimensions (width, length), electron/hole diffusivity, and the minority-carrier lifetime.
    Dave
  4. studiot
    Nov 9, 2007
    5,005
    515
    Try to think of it this simple way.
    A transistor has three legs (terminals).
    Therefore it has three terminal currents Ie , Ic, and Ib
    By Kirchoffs current law, since they all meet at a point within the transistor
    Ie+Ic+Ib = 0
    We can also define three ratios with these currents, however only two are independant, we can always get the third by cross cancelling.
    Originally the two that were chosen were called alpha and beta, after the first two letters of the Greek alphabet
    So
    alpha = Ic/Ie
    Beta = Ic/Ib
    Whatever these values turn out to be.
    The fact that these values have desireable properties makes the transistor such a valuable device.
  5. DickCappels
    Aug 21, 2008
    2,774
    671
    Everybody knows where β comes from: The datasheet!
