1. diwa2000@gmail.com
    Thread Starter Active Member
    Apr 15, 2008
    40
    can a comparator read the out form the integrator circuit....the output of which is a negative voltage ramp.... and compare that with a reference voltage. Geneally whats the output of a comparator ...is it only high(+5V) or low(0V)... or anything else also.
    Please clear.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Here is the material covering comparators in the AAC ebook.
    hgmjr
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The input and output of a comparator depend also on the powersupply.
    If a comparator is connected to a powersupply that gives say +15 Volt for the positiv powersupply and -15 Volts for the negativ powersupply, than the output will swing between + 15 Volt and -15 Volt, depending on the inputs.
    The reference voltage may be negativ in this case.
    Greetings,
    Bertus
  4. mik3
    Feb 4, 2008
    4,846
    63
    Yes you can do it. Your comparator's output will swing between the two extreme voltages of your power supply. Thus, if you have a single supply (eg. 0-15 V) the output will rise to nearly 15 if the non-inverting input is more positive than the inverting input and to near 0 if the opposite happens. If you have a bipolar supply (eg. 15-0-(-15)) your output will go to near 15 if the non-inverting input is more positive than the inverting input and to near -15 if the opposite happens.
  5. diwa2000@gmail.com
    Apr 15, 2008
    40
    thanks mik3
