Doubt on clamping circuit.
Discussion in 'General Electronics Chat' started by simpsonss, Aug 24, 2011.
  1. simpsonss
    Thread Starter Active Member
    Jul 8, 2008
    173
    hi,
    I'm constructing the biased clamping circuitas below. From what I know, I would get a signal as the second diagram. But when I measure from the scope I get the different result which is different with the one I expected. Can anyone help me on this?
    the input signal is 38.4Vpp.
    the output signal is Vb= 8V which is as shown in the second diagram. what is expected is Vb = 5V.
    Thank you.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    The diode forward drop will add to the resulting peak value. Also if your 5V battery has any appreciable internal resistance the peak value will be higher still. What are the actual components you are using? Diode type, etc?
  3. simpsonss
    Jul 8, 2008
    173
    hi, thanks for the reply. 5V component is from a 5V output adapter. and i'm using 1N4002 for the diode.
  4. ErnieM
    Apr 24, 2011
    7,436
    1,625
    1N4002 is a poor choice for this, it is best suited for slow speed/high current, such as a bridge rectifier. Instead try a nice small signal diode such as a 1N918 or a 1N4148.
