Doubt in worksheet of Clippers
Discussion in 'Feedback and Suggestions' started by manuj, Dec 8, 2010.
  1. manuj
    Dec 8, 2010
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    Nope, the graph is correct.
    Remember, you can see the voltage when it is applied across the diode and is blocked by it, not when it is drained through it because of forward biasing.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    This is somewhat simplified. But then a diode is forward biased. Think about it as a closed ideal switch. Then an ideal switch is closed. It will have zero voltage drop
