doubt in time shifting the signal
Discussion in 'Homework Help' started by bhuvanesh, Feb 17, 2015.
  1. bhuvanesh
    Aug 10, 2013
    268
    i am experiencing problem in time shift when the signal is in negative axis .Help me solve this.Thank you in advance
  2. shteii01
    Feb 19, 2010
    3,500
    511
    f(t) and w(t) are the same. But they are located in different places on the t axis.
    If you shift f(t) 2 places to the right, f(t) becomes w(t). So. w(t)=f(t-2)
    The general formula (straight from the first chapter of my textbook) is this:
    w(t)=f(t-T)
    - if T is positive, the signal is shifted right (delayed).
    - if T is negative, the signal is shifted left (advanced).
    If your textbook can not explain shifting, then you really need to be afraid of convolution.
    bhuvanesh likes this.
  3. bhuvanesh
    Aug 10, 2013
    268
    got it
  4. glaxy
    Feb 23, 2015
    only have basic skills with PLC programming. I think it might be the FX PLC ? I have the first few lines however I'm unsure on the sensor part to stop the conveyor belt and restart. Thanks for the reply:p smug post have good!!!!!!!!!!!!!!!!!
    adil
