Doubt in Non inverting amplifier
Discussion in 'General Electronics Chat' started by sudharshan.panduranga, May 10, 2010.
  1. sudharshan.panduranga
    Thread Starter Active Member
    Apr 10, 2008
    61
    Help me...
    In the OPAMP non inverting amplifier, I have one doubt..
    Specification:
    Supply voltages : +/- 5V
    Gain : 10
    Input voltage : +6V
    Why opamp output gives -ve voltage. Can anybody give the reason.
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    The input voltage may not be higher than the powersupply voltages.
    What type of opamp did you use?
    There are older types that reverse the phase at a to high input.
    Bertus
  3. sudharshan.panduranga
    Apr 10, 2008
    61
    The OPAMP: OP27A
  4. sudharshan.panduranga
    Apr 10, 2008
    61
    I Am using OP27A low noise OPAMP.
    Is there any theoretical reason.
  5. t06afre
    May 11, 2009
    5,939
    1,222
    Have you downloaded the data sheet? This may be somewhat blunt. But what you are trying to do is futile, and it may fry the opamp. As the data sheet say the absolute maximum input voltage can not be higher than the supply voltage.
    Tell us what you are trying to do, and we will help you
  6. sudharshan.panduranga
    Apr 10, 2008
    61
    I am not using this condition in the implementation. But i should know the reason reason...Can you suggest the reason...:)
  7. rjenkins
    Nov 6, 2005
    1,015
    69
    If you operate ANY IC outside of the manufacturers specifications, it will either work poorly, malfunction or plain blow up.
    The exact type of fault or failure varies from device to device, but the fundamental cause is using the device beyond it's ratings.
    If you want more technical reasons, look at the fundamentals of integrated circuit construction, substrate isolation & thyristor effect, in addition to basic transistor biassing and breakdown vltages.
  8. sudharshan.panduranga
    Apr 10, 2008
    61
    Thanks to all !!!!!!!
