doubt in master-slave circuits
Discussion in 'General Electronics Chat' started by elisettynarendra, Oct 3, 2010.
  1. elisettynarendra
    May 17, 2010
    42
    in jk flip flops , o/p is connected to i/p so there arises the problem of race around condition. so we go for master slave jk flipflops to eliminate that.
    but i observed master slave design for sr flip flop's too. where sr flip flop's don't have feedback(so no chance of race around). do MS-SR flip flop have any advantages over normal sr flipflops.plz correct if i am wrong.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Anything with a master/slave configuration can be wired to toggle. Why bother otherwise? With toggling comes the ability to count. With counting comes advanced logic, as well as clocks, frequency counters, and other nifty devices.
    If you want more input you need to include a schematic.
  3. elisettynarendra
    May 17, 2010
    42
    but in masterslave sr flipflop we dont get a race around problem and toggle condition..we only get a toggle in jk flipflop where o/p is fedback to i/p..
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    You'll note the input on the schematic has a clock, what do you think I was talking about?
  5. kubeek
    Sep 20, 2005
    4,686
    805
    Difference is that Master-Slave flip-flops are trigered by clock edge, while single flip-flops are triggered by clock level. Thus MS are better, because the edge is one very short moment compared to the length of one logic level of the clock signal, so the transition happens more in "one exact time".
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Actually a simple set/reset flip flop isn't triggered at all, at least not by a clock. There are analog ways to get around this, but in a purely digital world you have to have two flip flops (master/slave) to toggle on a pulse.
    If anyone knows any exceptions to this I'd be interested, I've put a bit of thought into it. This...
    can not be used in a counter.
  7. kubeek
    Sep 20, 2005
    4,686
    805
    E is the trigger. And if you connect clock to it you can make seqential circuits.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    But not count, which is the core point I've been making. You could use two of them, but then it would be a master/slave.
    Unless you know of a way to illustrate I'm wrong? I draw my examples.
  9. elisettynarendra
    May 17, 2010
    42
    @kubeek
    if that is the only purpose we are going for MS flipflop , if we use the circuit for 'E' , the flipflop will be triggerd at edges.
    why cant we use simpler SR circuit with this triggering ..instead we can avoid high propagation delay which occurs in case of MS-SR flipflops.
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    What you are looking at is a latch and hold, which has a whole different set of uses.
    Various configurations have different jobs, they do different things. Latch and hold are good for displays for example, they will keep the display still while the counters are working.
    The SR does not count, it can't. It can "remember" a previous state. It is a memory cell.
    Anytime you want a clock input you need master/slave, but counting is a different job.
    There are actually many different configurations for flip flops, each does a different job. D type flip flops are also a master slave, but they are used for shift registers.
    Try reading Wikipedia for the various types.
  11. elisettynarendra
    May 17, 2010
    42
    thanks bill..i will search for the other applications ..
