Doubt in GSM sim900 interfacing with atmega16
Discussion in 'Homework Help' started by shubh agrawal, Mar 9, 2015.
Thread Status:
Not open for further replies.
  1. shubh agrawal
    Mar 9, 2015
    Right now I am trying a simple code of calling by GSM sim900 using atmega16
    MY SETUP:Rx and Tx pins of atmega board are connected to Tx and Rx of my GSM modem and also to my uart bridge which i connect to my PC(done by splitting the Rx and Tx pins)-This was done so i could know whether my AT commands were given to modem or not
    OBSERVATION;
    AT commands appeared as i wanted in terminal(X-CTU I have Used) that means they were actually given to modem also(since i splitte the wires).But no call was made.However when i myself entered the AT commands During the same process I was succesful
    MY code:
    #define F_CPU 12000000UL
    #include <util/delay.h>
    #include <avr/interrupt.h>
    #define BAUD 38400 //setting up baud rate
    #define bd (int)(F_CPU/16/BAUD-1) //value of UDRR to be set
    #include <avr/io.h>
    void command(char*a) //function to send a string using pointers
    int i;
    for(i=0;a!='\0';i++)
    while(!(UCSRA&(1<<UDRE)));
    UDR=a;
    _delay_ms(100);
    flush ISR (USART_RXC_vect) //flushing any type of echoes obtained
    char recdata;
    recdata=UDR;
    int main(void)
    sei();
    UBRRH=(bd>>8);
    UBRRL=bd;
    UCSRB|=1<<RXEN|1<<TXEN|1<<RXCIE;
    UCSRC|=1<<URSEL|1<<UCSZ0|1<<UCSZ1;
    _delay_ms(2000);
    command("AT\r");
    _delay_ms(2000);
    command("AT\r");
    _delay_ms(2000);
    command("ATD+919933988118;\r");
    _delay_ms(20000);
    command("ATH\r");
    while(1)
    Can any one please help me why my atmega is unable to do so or is there any problem in my code?
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
Thread Status:
