230 v I´m in Europe. You might be right, this cable is for use in industrial machines, but I´m using it as a power lead!Here is the cable :Usually means that the insulation is rated for 4Kv, why you would need that on a 120v stereo I am not sure?
Usually power cords are rated 600v max.
It is a 60 Watts amplifiers, but is expensive and has lots of current!What is the current consumption of the amp.?
Max.
Yes, 60 Watts is the áudio outputI assume the 60w is the audio output, there should be a label that applies to the AC input somewhere, voltage/current etc.
Max.
It is 3 conductors*1,5 mm2(3*1,5 mm2). Is more than enough!Hopefully someone familiar with such can give you guidance as far as the gauge (size of conductor area).
The current rating is probably OK (based on the information provided) but personally, given the voltage, for safety's sake, I'd rather see you go at least 2,08- to reduce the possibility of shearing or other such damage, among other things. Again, I'm not familiar with your country's electrical codes. If no one with such knowledge responds on this forum, I suggest you consult a local repair shop for guidance.It is 3 conductors*1,5 mm2(3*1,5 mm2). Is more than enough!
No need for thanks. Hopefully we've helped in some way. Enjoy the sound!Thank you!
Thread starter | Similar threads | Forum | Replies | Date |
P | A doubt from RF Electronics, Razavi | Wireless & RF Design | 1 | |
P | RF Doubt | Wireless & RF Design | 0 | |
I have doubt in mplabx ide I code | Microcontrollers | 1 | ||
F | Transmission lines doubt | Homework Help | 0 | |
I have a doubt with respect to capacitor's role in low pass and high pass filter. | General Electronics Chat | 6 |
by Don Wilcher
by Duane Benson
by Jake Hertz
