doubt about OBD II
Discussion in 'Embedded Systems and Microcontrollers' started by ep.hobbyiest, Jul 16, 2015.
  1. ep.hobbyiest
    Aug 26, 2014
    94
    hi,
    i m working on can bus now, i want to know whether OBD II can send CAN frame to CAR's network.
  2. cork_ie
    Member
    Oct 8, 2011
    348
    58
    You will need to check which CAN networks are connected to your 16pin DLC socket and the pinouts .
    Quite often on newer vehicles the DLC has a direct CANBus connection, but there can be several different CAN networks all interconnected through a CAN Gateway , a kind of convertor /router. You will probably be only able to send CAN frames to the directly connected network
