doubt about digital dimmer
Discussion in 'The Projects Forum' started by tsalagi, Mar 1, 2010.
Thread Status:
Not open for further replies.
  1. tsalagi
    Feb 14, 2010
    Hi everybody,
    I found in a very known magazne a remote-controlled digital dimmer that I have planned to make. Although you can get similar dimmers in shops, this one seems exceptionally great. My question is: this dimmer was created to operate under 230VAC, with the possibilte to change the circuit for a 12VAC lamp. To construct it, should I make some changes to the original circuit, considering that mains where I live ar 110/120VAC? Will it work with no changes? Does this affect the zero-crossing calculation? I haven't worked with mains directly, so I don't know much about that. If someone can help me, I can post concrete info about the project. by now, i'm posting a circuit pic. It explains the that the green values are for testing with a 12VAC lamp before the final mounting. Thanks
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Sorry, but that notice about how "contact can be fatal" puts it outside our guidelines.
Thread Status:
