DoubleHeadphoneDistributer
Discussion in 'The Projects Forum' started by mpuvdd, Sep 21, 2007.
  1. mpuvdd
    Thread Starter Active Member
    Feb 11, 2007
    50
    Hello everyone,
    I'm working on building a small circuit to simply distribute an audio signal from an iPod, to two headphones. How would I go about balancing the headphones (cause they could have different resistances), and do you think that the signal would need amplification?
    Thanks for all the support,
    mpuvdd
  2. mozikluv
    Jan 22, 2004
    1,437
    here's a very simple circuit for that. improvements are welcome:)
    moz
  3. cumesoftware
    Apr 27, 2007
    1,330
    11
    The headphone drivers have 16Ohm each. Did you took that into account? It seems that a lot of signal will be lost.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    You can buy them with individual volume controls for around $5 - $10 US. Anything you can build would be big and ugly. Google "headphone splitter volume control".
  5. mpuvdd
    Feb 11, 2007
    50
    Cool, well alright, I geuss I'll probably buy one since they're so cheap.
    Thanks for all the help guys. :D
  6. Ashok Gupta
    Sep 25, 2007
    simply connect the two headphones in parallel.
    There is no need of amplifying the signal as power requirement of the headphones is very low.
    I think that there is only little variation in the impedance of two headphones.So u may match the impedance but it is not necessary.
  7. Ron H
    Apr 14, 2005
    7,050
    657
    If the headphones are from different manufacturers, or are just different models, the impedances could be very different.
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If there is an impedance mismatch, the audio signal will be distorted; particularly at higher volume levels.
    The impedance of iPod headsets is 32 Ohms; standard headsets are 4 or 8 Ohms. Obviously, the iPods' output was designed to work optimally with an iPod headset; I can only surmise they chose 32 Ohms as a power-saving and/or weight-saving feature.
    In order to properly match other headsets, you'd need to use a matching audio transformer at the very least. Attempting to connect a low-impedance headset would certainly result in a great deal of distortion at higher volume levels.
    As a reminder; keep the volume low enough so that you can hear ordinary conversations above the music - otherwise, you will likely cause irreversible hearing damage.
  9. Brennn10
    Sep 13, 2007
    5
    could I use 2 3.5mm line sockets, connected to a male headphone jack?
  10. Brennn10
    Sep 13, 2007
    5
    So I stripped my stereo plug, now how do i connect it to the two stereo inputs?
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    A stereo headphone will have three or four connections. One or two are signal ground, the others are +right and +left.
    A 1/8" stereo plug has three connections. There are three areas of connectivity on the plug; the tip (+left)), a band near the tip (+right), and the signal ground.
    This page has a lot of helpful information:
    http://www.headwize.com/faqs.htm
