double sided prototyping board
Nathan Hale
Joined Oct 28, 2011
159
Hi folks. Why and when do people use double sided prototyping PCB board? Tried googling the question and got nothing.ty
jpanhalt
Joined Jan 18, 2008
11,087
Those boards are single pad per hole and are through-hole plated. That allows you to have components on one side and connections/wires on the other with easy soldering of either. John
wayneh
Joined Sep 9, 2010
17,498
Yup, those are very much like the ones I use, and they're very nice to work with. The thru-holes are much more robust than the old brown boards without plated thru-holes.
Components could go on both sides, but I admit never using one that way - too hard to design. I put components on one side and most of my interconnects on the opposite side. A few wires on either.
Depending on the board you get, I have a very nice drawing template already to use.
takao21203
Joined Apr 28, 2012
3,702
the browns are better imo, u can remove components again and break them into pieces.
