Looking at the image in your post #78 it appears that the Y axis is set for 5V/division on the CRO graticule.?Yes, but that's not what it's in the positive half-cycle... In the positive half-cycle we can see 5.2V which is + 0.6V than what it should be!
Measuring between the clipped positive and negative levels I read ~ 11V, which is close enough to 6.3V + 4.6V = ~ 10.9V which I posted in post #79
So what exactly what are you saying , ??
If you are using actual zeners and diodes in a circuit and you are now using a ~20Vpeak to peak sinewave, compared to a 8.48Vpk waveform in simulation, I would expect to get a different result!!
