Double Integral
u-will-neva-no
Joined Mar 22, 2011
230
Hello everyone, I am having difficulty with this double integral.
I was given the following integral:
\( I =\int ^1_0 dx \int ^{2x}_x 2xy dy \)
I have to reverse the order of integration and so this was my approach:
I first plotted the graph of the above and is attached as 'integrate along y'.
So then I integrated along x so the lower limit is y and y/2. The second image to show what i was thinking is shown as 'figure 2'.
So the integral that I get is:
\( I =\int ^1_0 dy \int ^{y}_{y/2} 2xy dx \)
However, my solution comes to 3/16 whereas the answer should be 3/4.
Thanks fore reading and hopefully one could explain what I am doing wrong!
steveb
Joined Jul 3, 2008
2,436
The region you are integrating over is bounded by three lines, not two.
There is y=x, y=2x and x=1. They form a triangle shape. Recheck your limits and you will see that your new integral does not span over the same triangular region.
u-will-neva-no
Joined Mar 22, 2011
230
Thanks steveb. One other issue that I am having is the following. For the first integral that I wrote, the limits for the first part of the integral are 0 and 1. I used the second integral limits to arrive at the two equations (y=x and y=2x) and from previous examples, i would combine the two together to arrive at the limits for the first integral. This does not work in this instance.
The reason why I am asking this is because I am confused what to put for the first integral for when I reverse the order of integration.
