Thank you sir I will check it right awayIt appears I misremembered, a fourth 555 was used to create an inverter. I drew several versions, this was one of them...
This was the thread...
http://forum.allaboutcircuits.com/showthread.php?t=17499
Thread starter | Similar threads | Forum | Replies | Date |
Need help to double check LM317 circuit | Power Electronics | 10 | ||
J | [SOLVED] My multimeter reads double the AC voltage | Test & Measurement | 8 | |
Double equals in C | Programming & Languages | 52 | ||
Y | fixing double inverting series two stage opamp amplifier | PCB Layout , EDA & Simulations | 38 | |
J | Double Flash Strobe Effect | General Electronics Chat | 18 |
