double-ended forward converter
Discussion in 'Homework Help' started by notoriusjt2, Nov 17, 2010.
  1. notoriusjt2
    Feb 4, 2010
    209
    Vs=100
    N1/N2=1
    N1/N3=1
    Lm=1mH
    Lx=70uH
    R=20ohms
    C=33uF
    D=0.35
    f=150kHz
    determine output voltage
    in the chapter for "Double-Ended forward converter" it states the following..."The output voltage is the same as for the single-ended forward converter" and points to the following equation
    Logically speaking, if the transformer turns ratio is 1/1, then wouldn't the input and output voltage be same assuming an ideal situation?
