Double beep circuit
Discussion in 'General Electronics Chat' started by sebastianpatten, Mar 1, 2011.
  1. sebastianpatten
    Nov 28, 2010
    18
    Hi there I've been looking for a double beep circuit. For example something that would do two beeps quickly, back to back then a pause and repeat.
    Any ideas on where i can start?
    Many thanks!
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Use a CMOS 555 timer wired as an astable multivibrator for a clock pulse to drive a 4017 5-stage Johnson counter. Use 10k Ohm resistors from the 1st and 3rd outputs to the base of a Darlington transistor that has its' emitter grounded, and connect the buzzer between the collector and +V.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Or two 555s, one fast, one slow, both oscillators.
  4. sebastianpatten
    Nov 28, 2010
    18
    Thanks guys - any diagrams to go with your answers? It would be of great help.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Have a look at the attached. I used a 4093 quad Schmitt trigger NAND instead of a 555 timer; makes for a low parts count. As shown, it gives 2 quick beeps every ~1.5 seconds.
    Power connections to the ICs are not shown, neither are 0.1uF ceramic or poly bypass capacitors, which are required.
    I don't know what kind of buzzer/beeper you'll use. This circuit should be good for one that requires up to 120mA at 12v.
  6. sebastianpatten
    Nov 28, 2010
    18
    Wicked thank you for taking the time SgtWookie - it really is appreciated. People like you help make the world turn round and be a better place.
    Have a great day!
  7. sebastianpatten
    Nov 28, 2010
    18
    Cool - I've learned about Schmitt triggers and Decade counters now :)
