Doppler ultrasonic transducer
Discussion in 'The Projects Forum' started by projecthelp, May 4, 2011.
  1. projecthelp
    May 4, 2011
    I am presently working on a project to develop an ultrasonic doppler fetal heart rate monitor.
    I have a doubt in the first stage of this project i.e the data acquisition part
    This is the transmitter part
    DOUBT- What are the specifications of the transformers T1 and T2 in this fig, these transformers have to be small so that they can be soldered on a pcb becoz the final device has to be portable.
    DOUBT- same as above I need specifications (winding ratios) of transformers T3 and T4
    NOTE: This PDF explains construction and working of this ckt you can use this for reference http://blockyourid.com/~gbpprorg/mil/ultra/Build_This_Doppler_Ultrasound_Monitor.pdf
    please reply fast
    thank you
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    All the components are in the parts list. The manufacturer of the transformers may give the winding ratios.
