First, the attached -1 .asc file is what it takes to make the simulation run: As drawn; you had the entire circuit "floating", with no reference to Gnd. The voltage source driving the switch doesn't count.Mike,
Here you go, thanks in advance.
I originally had a LED/resistor between the two for testing. When the 555 pulses the base of the resistor, the circuit is open, which is what causes the NC alarm zone to "alarm."
Tom
Second, your drawing style sucks. the attached -2 .asc file is the circuit redrawn in such a way that I can understand it: supply rail on top, grounds facing down, power supply and inputs on the left, outputs on the right. Most current flow from top to bottom.
I also labelled some nodes so I can see what they are in the plots. I eliminated some unnecessary components.
The "short" through the transistor is not as bad as I initially thought because the base current is starved by the 10K base resistor.
