Door lock keypad
Discussion in 'The Projects Forum' started by snow_blitzz, May 3, 2016.
  1. snow_blitzz
    Apr 14, 2016
    5
    Hello, before I continue I would like to let you guys know that I'm a novice using Circuit wizard.
    I'm using the Genie E18 board (it's a must) and I'm trying to do so that I can press a certain number. For clarification, Pin 1 (row 1) and pin 2 (column 1) should result in the number 1 as it is the intersection of the two pin. However It seems that I cannot figure out how to make it so that it would ONLY be number 1 and not the rest of the numbers on row 1 and column 1 (2,3,4,7,*). So my question is how do I programme so that it would only be a CERTAIN number and not the whole 7 numbers (3 in a row, 4 in a column)?
  2. Colin55
    Member
    Aug 27, 2015
    204
    21
    You have to scan the keyboard by delivering HIGHs to it and looking for a LOW or a HIGH.
  3. GopherT
    Nov 23, 2012
    6,300
    4,020
  4. snow_blitzz
    Apr 14, 2016
    5
    Can someone please show a circuit wizard flowchart to replicate this?
  5. Colin55
    Member
    Aug 27, 2015
    204
    21
    You need in-out for a keypad. The Genie E18 has 8-out and 5-in. You have to show how the keypad is wired.
  6. GopherT
    Nov 23, 2012
    6,300
    4,020
    No, you are the only user of Circuit Wizard - I've never heard of it.
    absf likes this.
  7. Colin55
    Member
    Aug 27, 2015
    204
    21
  8. snow_blitzz
    Apr 14, 2016
    5
  9. Colin55
    Member
    Aug 27, 2015
    204
    21
    We need to know the keypad configuration.
  10. snow_blitzz
    Apr 14, 2016
    5
    What do you mean?
  11. Colin55
    Member
    Aug 27, 2015
    204
    21
    I think this whole thing is beyond your capabilities.
  12. snow_blitzz
    Apr 14, 2016
    5
    Bringing this thread back to life, why doesn't this work?
  13. Colin55
    Member
    Aug 27, 2015
    204
    21
    You cant make lines high and low. You have to have inputs and you need pull up resistors.
    You need 5 years of electronics study before starting to develop a program for a keyboard.
