Door bell should ring automatically on my car's arrival
Discussion in 'The Projects Forum' started by bilalk, Nov 2, 2010.
  1. bilalk
    Oct 12, 2010
    5
    Hi 2 all, I need a bit of your help to get started for my first electronic project. I want to make a transmitter and reciever circuit.The receiver CIRCUIT will sense my car's arrival and will ring my door bell.A transmitter will be in my car.
    Is there a common circuit for this purpose that i can use for my project? Any suggestions about the cct diagrams ,approach and other ideas are welcomed and will be thanked.
  2. lihle
    Apr 12, 2009
    83
    okay here is one idea you can use. what you can do is to use the idea of beam interruption whreby if the beam has been interrupted your control circuit will transmitt a certain code to the receive and then upon detection the bell would be activated. the transmitter can be place at the gate.
    lihle
  3. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Simple is a hose with a pressure switch on the end. Run it over and it closes a contact & rings a bell. Just like the ones at old full service gas stations.
  4. windoze killa
    Feb 23, 2006
    605
    24
    Before getting too complex or too simple do you want the door bell to ring when YOUR car arrives only or when ANY car arrives?
