Domestic Automotive Generator
Discussion in 'Homework Help' started by joejohnson, Oct 8, 2008.
  1. joejohnson
    Oct 8, 2008
    On the generator is a label that contains numbers. Can you give me a site I can retrieve an illustration of the generator and label as well as a detailed explanation of the label numbers?
  2. neon9
    Member
    Oct 8, 2008
    15
    with this info NO WAY
  3. loosewire
    Apr 25, 2008
    1,584
    435
    Search -Understanding the alternator,See if that helps you.This is
    a working site,it has 35 pictures taking apart an alternator.Showing
    every part of the alternator.It describes internal cooling methods
    that exist.This will be enlighten to many that like mechanical things.
    LOOSEWIRE- ALL RIGHTS DESERVED
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Do the numbers relate to the output in volts, amps and power?
