I'm hoping to find a rather simple and cheap solution to capture, compress and record a NTSC video input.
I'll probably be using ADV7180 for capturing a NTSC signal and converting it to 8bit YCrCb.
I'm hoping to use a FPGA for compression and as a storage controller for a fast SD card. I guess the design will also require several RAMs, maybe other ICs I haven't thought about...
I'm fairly new with video and just started researching this field, so any tips you can throw at me will be a huge help. Am I in the right direction here? Should I use a dedicated IC for the compression? Are there any development kits to help me out?
