Hello people
Looking for anwers on a schottky diode.
Connect 6 volts gel battery using Schottky Diode experiment with following schottky diode( 1n5822,1N5817) .
First experiment was connect cathode side of diode to postive side of the battery got reading around 6 volt.
Second experiment was to connect the anode side of the diode to postive side of the 6 volt battery also got reading around 6 volts.
Should diode block voltage on one side (should be zero reading on one side of diode connection).
mrel
mrel
