On another forum, we were discussing ways to step down the voltage from 120 to 100 volts, this in order to make japanese radios work with USA voltages. Japan mains is 100volts. Somebody posted a suggestion. Somehow, I don't see how it will work. Since I trust you guys, please comment on whether this will work and why it will/won't work. Thanks.
Here it is:
Heres a trick to reduce the voltage using a transformer.
Connecting the 24 volt out backwards to subtract voltage from the 120 volts AC.
Will give you close to 100 volt needed.
Here it is:
