Does this connector have a name?
Discussion in 'General Electronics Chat' started by BringMeAnother, Aug 24, 2014.
  1. BringMeAnother
    Oct 21, 2012
    12
    http://www.talktoanit.com/A+/aplus-website/images/multimeter2.jpg
    I'm talking about the pointy ends with the red and black connectors usually found in multimeters which are called measuring lead and reference in the image. They are 2mm in diameter. I'm looking for the female connector. It's as if I wanted to build an extension for it except that it's not my end goal. Thanks.
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
  3. BringMeAnother
    Oct 21, 2012
    12
    Thanks. Would you happen to know if it is sold anywhere a splitter that would have one female 2mm jack and two male 2mm jack? The two male 2mm jack can be 4mm banana jacks because I found on ebay adapters from 4mm female to 2mm pin jack. However, I have not found the other way around, that is 2mm female jack to 4mm banana male jack.
  4. KJ6EAD
    Apr 30, 2011
    1,426
    364
    Check Pomona, Mueller and E-Z Hook.
