... because in my simulation it doesn't seem to be working.
The control voltage is being set quite low, but the ramp waveform is stuck high. I really need it to follow the control voltage for my PWM generator to work. I'm sure I'm missing something...
I am using an LM324 at the moment for convenience as it has a push-pull output. But later I will use a proper comparator.
10 bonus points for figuring out what this circuit actually does .
Blue trace represents ramp voltage. Green represents control voltage. As you can probably see the ramp voltage exceeds the control voltage
