I thought they were using double lines for reliability issues, and also because a wire of the proper gauge would be impractically thick and heavy...Cool! Learn something new every day!
You say it stiffens the lines... is that due to electromagnetism?
Fascinating article, I found the Litz wire rather interesting too.Skin effect. 9 mm conductive layer for copper, 11 mm for aluminum (@ 60 Hz.).
Reference: http://en.wikipedia.org/wiki/Skin_effect
Cables are designed with this in mind -- the core is there primarily for strength without much, if any, concern given to conductivity.Fascinating article, I found the Litz wire rather interesting too.
So that would mean that the maximum practical cooper wire gauge working @ 60 Hz would have a diameter of 18mm, right? How about making a hollow wire with a 9mm wall thickness, would that work as well?
So now I wonder, are there cables whose core is of a different and cheaper material than its skin?Cables are designed with this in mind -- the core is there primarily for strength without much, if any, concern given to conductivity.
There are cables that have no core. I saw a picture of the feed line to a 50kW AM radio transmitter antenna and it looked like a big copper dryer vent hose. I'm guessing it was a foot or so in diameter and very thin walled. I don't know if that style is common for such applications or not.So now I wonder, are there cables whose core is of a different and cheaper material than its skin?
Now that you mention it, I recall that cooper tubing is used in induction heating applications, which usually run at high frequencies. And this is also taken advantage of by pumping liquid coolant through them.There are cables that have no core. I saw a picture of the feed line to a 50kW AM radio transmitter antenna and it looked like a big copper dryer vent hose. I'm guessing it was a foot or so in diameter and very thin walled. I don't know if that style is common for such applications or not.
Yes, although the wire I saw was probably more for marketing reasons than any practical application. There was a HiFi shop that had copper core, silver outer cable for speaker connections... almost the thickness of my little finger per "core"... it was also some incredibly crazy price per metre.So now I wonder, are there cables whose core is of a different and cheaper material than its skin?
I'd like to have a sample of one of those cables, connect them to my amp and speakers, and test them with an oscilloscope... see if the frequency response is noticeableYes, although the wire I saw was probably more for marketing reasons than any practical application. There was a HiFi shop that had copper core, silver outer cable for speaker connections... almost the thickness of my little finger per "core"... it was also some incredibly crazy price per metre.
I can almost guarantee that the difference in response will be hardly noticeable -- it might me measurable, but it is very unlikely that any human would be able to really tell the difference. There have been a number of controlled studies and the audiophiles have not fared well in any that I am aware of.I'd like to have a sample of one of those cables, connect them to my amp and speakers, and test them with an oscilloscope... see if the frequency response is noticeable
And if this were Star Trek, they'd buy duranium alloy speakers...I can almost guarantee that the difference in response will be hardly noticeable -- it might me measurable, but it is very unlikely that any human would be able to really tell the difference. There have been a number of controlled studies and the audiophiles have not fared well in any that I am aware of.
But because audiophiles believe that they are so sophisticated that they can tell the difference, they are easy marks for scams. Basically, someone tells them that their latest and greatest wowium-plated cables at $100/ft are the newest, hottest, best thing around and they will buy them and convince themselves that they are, indeed, far superior and worth every penny.
Would you please elaborate?Every un-connected circuit in your house has charge flow.
A little off-topic, but speaking of high heights...It didn't give me a giggle... it gave the willies... I'm afraid of heights... and I'm afraid of high voltages... and I'm afraid of high voltages on high heights...
by Aaron Carman
by Jake Hertz
by Aaron Carman
by Aaron Carman
