Does position of loads on a circuit matter?
jellytot
Joined May 20, 2014
72
Let's say I have a 5V output on a voltage regulator, and I have a 5V motor that draws 1A (rapid and short on-off cycles), and a CPU that takes 5V and draws 20ma. Does it matter which load comes "first" (closest to the regulator output), so that there is less chance of the CPU resetting itself?
Sensacell
Joined Jun 19, 2012
3,448
I think you know what is going to happen.
DC motor and CPU on the same power bus- you will need to take great care to prevent the CPU from crashing from noise and / or dropouts.
The motor doesn't care.
34,452
Motor has flyback diode, and grounds are separate. Random resets of the CPU still occur, so I'm wondering if the load order on the power bus has an effect.
Absolutely.
But the correct answer is that you don't want them on the same bus at all.
They should each have their own bus wire going directly to the power supply (star connection).
And the CPU should be well decoupled with both a 47μF capacitor across the CPU power bus and a 0.1μF ceramic capacitor directly across the CPU power pins.
jellytot
Joined May 20, 2014
72
I have a 330μF aluminum cap and a 0.1μF ceramic capacitor directly across the CPU power pins. I'm afraid I don't know what you mean by a "capacitor across the CPU power bus". May I trouble you (or anyone willing) with a schematic or diagram of this?
Sensacell
Joined Jun 19, 2012
3,448
Scope the power bus, turn the motor on and off- see what the voltage does.
DC motors look almost like a dead short at 0 RPM, chances are your regulator is dropping out.
In this case, the only solution would be to limit the motor inrush current with some means, maybe a resistor that gets shunted once the motor revs up?
Picbuster
Joined Dec 2, 2013
1,047
A quick explanation why you have to be careful.
This should give to an idea where and why to put what.
hp1729
Joined Nov 23, 2015
2,304
the heavier load should be closer just to keep the wires shorter.
Lestraveled
Joined May 19, 2014
1,946
@jellytot
We are approaching this problem from the wrong direction. Lets turn this question into a statement. A CPU, randomly resetting while controlling a heavy load, such as a motor, is a clear indication that power management and distribution has been done incorrectly. @Sensacell was right on about the causes of this. Electromechanical devices like motors are hell on power supplies. When the rotor is not moving and full voltage is applied, the motor will appear more as a short than an inductor. Can your power supply and distribution handle a dead short for a half a second?? Of course not.
You need to rethink how your power supply system works. Redesign your power supply so the voltage feeding the CPU is unaffected by a stalled rotor/short on the motor. The approach suggested by @Alec_t might work well for this application.
But how the diodes would mask the voltage drop, Alec? If it goes down for one it goes down for the other? Am I wrong?
The diodes isolate a dead short on one leg, from drawing the voltage down on the other leg. While the short is occurring, the other leg is literally running on energy stored in its capacitor. So, the capacitor must be sized to operate the CPU for a half second by itself.
I suggest that the diode isolation be used before the regulator of the CPU.
